Help, Whats wrong with my tranny???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xplosuv, Mar 10, 2001.
  1. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    I have a 76 blazer, When I put the colum shifter in to #1 it grinds and "chunks" forward. this onlyhappens when it is in 1. there is nothing wrong when im in the D position in 2 or 4 wheel.? this has been like this for 4 years and I dont have a problem with the tranny other than that, so I dont use 1. Any body have any Ideas. Mystery problem. Thanks
    If you cant go over it...GO THROUGH IT !!!
    75 Jimmy 11" lift with 40's
  2. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    what tranny you have?
    I'm figurin a TH350 first thing I'd do is check your
    shifter linkage all the way to the trans and make sure its
    clicking in the right positions and not wore or bent
    worst case scenario would be a bad first gear
    does it even go into first gear in drive or straight to 2nd
    If it ain't intimidating / It ain't a Chevy!
  3. xplosuv
    Mar 9, 2001
    515
    Sacramento, CA
    Ditch,
    It works fine in the drive position, and i have checked the linkage.?
