HELP: whats wrong?
Discussion in 'The Garage' started by muddybuddy, Aug 26, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ok, my door locks stopped working. i went and got a new fuse and disconnected the battery and then put it in and reconnected battery and then they worked again. i started the truck up, and then it stalled out. i started it up again and then the door locks no longer worked. whats wrong? :confused: i gatta get it fixed asap so i can sell this thing.
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its a metal case circuit breaker, theres two, one is power windows and otrher is for locks
    check it or swap the two and seee if locks work then
    if not then its something else, broken switch or wire plug loose or corroded
    check grounds too
