help wheel bearing in my 14bff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GMCFIRST35, Dec 3, 2001.
  1. GMCFIRST35
    GMCFIRST35 Registered Member
    Dec 2, 2001
    38
    LARAMIE,WY
    how do you get the front wheel bearing out
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    undo the nut?
    maybe spell out your dilemma
  3. GMCFIRST35
    Dec 2, 2001
    38
    LARAMIE,WY
    the nuts off the wheel bearings catch on the hub
  4. michaelm
    Feb 2, 2001
    872
    ooohh
    by front you mean inner
    and you are trying the 'use the spindle nut to knock the seal off' trick
    BUT
    on your axle the spindle nut is larger then the hub will allow to clear?
    never seen that before, would suck though as you will most likely kill a reuseable seal.
