Help...where should I set timing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90idahoblazer, Aug 19, 2001.
  1. 90idahoblazer
    90idahoblazer 1/2 ton status
    Jun 24, 2001
    183
    Idaho
    I have a 1990.... 350 stock and was wondering where you guys set the timing? Do you set it at 0 deg BTDC like the lable on the truck says...and what happens when you retard the timing to much ....does your engine temp get hotter and RPM increase?.......thanks
    &lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by 90idahoblazer on 08/19/01 07:04 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by 90idahoblazer on 08/19/01 08:00 PM.</FONT></P>
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    Re: where should I set timing
    i have mine set at 10
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    does it run cooler or hotter....do the RPMS increase or does the motor rev higher or lower with that much advance?
  4. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Any other motorheads have any inputs on this?
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    you gotta realize where flblazer is from... you're NOT at sea level...
    I would just call your local dealer for settings, or give twiztid a PM... he works at a dealership, and is an awesome mechanic at about the same elevation as you are.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Since yours is a 90, it has an electronic advance control. This means the computer will try to advance your timing as much as it can without allowing any pinging or overheating. You should set it as the label says or you'll limit the computers ability to adjust it.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  7. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    Thanks Solo I did send him a P.M......He does live near me...My wife is from the same town he lives in....I think I have purchesed parts from the dealer he works at......
  8. 90idahoblazer
    Jun 24, 2001
    183
    Idaho
    anyone else have inputs
