help: where to order draglink ends?
Discussion in 'The Garage' started by muddybuddy, Jun 13, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, i have a superlift 4" draglink, but the ends are worn out. where can i get 2 new ends? they are different lengths than the stock ones, so i doubt stockers would work on it.
    thanks guys
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    IIRC the drag links have the same taper as the TRE's. Double check that with a parts catalouge (sp?) though. If they are, then you can research which ends you can replace them with based on the specs in the catalouge.
    However, I'm suprised that it won't work with stock drag link ends.
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    They are IIRC superlift order deals from them.. the threaded ends are Bigger then the 44/10 bolt threads in the stock draglink
    I had that arm for a little bit and one end was worn out..I took the arm and the old end and just started going though the ends they had..
    I belive the end I got was off a 86 ish 8 lug 10 bolt tie rod...I am not 100 % sure so just ask to see a few differant ones..
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so i should just go to a parts store and find draglink ends off of a 3/4 ton truck? the top and bottom ends have reverse threads, is this the same with the 3/4 ton?
    also, is there a site i can order the superlift ends?
