HELP!! Who has Mid 80's K5 w/Headers
Discussion in 'The Garage' started by CaveBlazin, Sep 14, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    HELP!! Who has Mid 80\'s K5 w/Headers
    Ok I need a pic of your left and right side of the engine and how you have your power steering pump hooked up. Even if you have just a shot of your engine please post. Thanks I thought I was almost done but the little crap is getting me /forums/images/graemlins/doah.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Re: HELP!! Who has Mid 80\'s K5 w/Headers
    IFAIK, I only had a problem with the A/C bracket. I used the stock manifold bolt on the front and a spacer to make up for the thickness of the manifold. Combined with the stock spacer and the thickness of the header flange and it was about perfect.
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i have an 85 with headers.. not sure if there is a useful pic in my webshots album or not. /forums/images/graemlins/confused.gif
    didnt have a prob with my headers... of course, I dont have an AC bracket anymore so... /forums/images/graemlins/whistling.gif
    j
  4. dyeager535
    26,977
    pics
    PS1, PS2, and PS3 on that page.
    Spacer on the first exhaust bolt came from a 4.3 engine, stock piece for the power steering bracket. Apparently not all 4.3's used a stock header on the drivers side, but many did. Believe that upper bracket came off of the same engine, no AC obviously.
    The rest of the PS bracketry (+ alternator and pulleys for crank and water pump) came from an '86 or '87 Monte SS. Had AC, so I had to come up with the non-PS brackets in the pictures. threw the bracket that ran to the very bottom back of the pump away, I couldn't make it fit no matter how hard I tried.
    I highly recommend the style I have...using a 5/8" wrench to adjust the belt tension, as the factory designed these, is so nice compared to the other bracket designs.
