HELP..WHY IS MY ENGINE VIBRATING????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wsudu, Feb 14, 2002.
  1. wsudu
    wsudu Registered Member
    Jun 30, 2000
    43
    Wichita, Kansas
    I started my truck the other day, and the whole damn thing vibrates a lot when you wrap it up just a little, maybe to 1400rpm. I checked the balancer, fine. I listened for anything unusual, nothing. It seemes to run fine, but It really vibrates. I mean if something really broke inside the engine, I would know it right, cause it runs fine. Any suggestions? Thanks Brian
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Could have a vacuum leak.
    Could be the choke is not working properly.
    Could be missing on a cylinder or two.
    Could be........?
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Motor Mounts going out...
    could be......
    Later <font color=green>KEN</font color=green>
    Fremont, CA
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    if it runs fine i would check the moter mounts. Does the engine torque over alot when you put it in gear or from drive to reverse?
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    motor mounts, have someone look while you are holding the brake and gas at the same time....(not in front of the truck of course). If the engine raises up high you will know...
    Surfing is Life...
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    maybe your sparkplugs are fouled up...
    <a target="_blank" href=http://community.webshots.com/user/bowtie1ton>My K5.</a>
    <a target="_blank" href=http://www.texasoffroad.net/galleries/members/midnight>http://www.texasoffroad.net/galleries/members/midnight</a>
  7. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I'll second the spark plugs being fouled as something to check. My motor was running fine when one dsay I started it and it was shaking at idle and anytime I was on the gas at low RPM, more gas made the shake worse. I was down on power too. A simple change of spark plugs and it runs smooth like it used to.
