HELP!!! Wierd noise coming from front or middle?
Discussion in 'The Garage' started by mudbog42, Feb 23, 2007.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Ok Just started yesterday, I here this wierd like metal banging sound while driving,:eek1: it sounds as if some piece of metal or something was connected to the tire and spinning around with it hitting the truck,:crazy: I've never heard this sound before so its hard for me to explain, but I have no clue what it could be.:confused: I think its coming from the front left, but could possibly be in the middle of the truck:rolleyes:
    I just parked it last night because it started to get worse as I drove on it
    Has anybody had this problem before or know what it is?:1zhelp:
    86 K-5 with manual hubs
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    is it a constant noise or does it seem to go with the rotation of the tire.. could be ujoint
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Yup must be a ujoint because I pulled the front driveshaft and the bearing cap on the front one fell off and all was rusted inside, then drove around with it off and it went away.
    So do you know where I can get some spicer u-joints and can I replace them myself or should I take it to a driveshaft shop
  4. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    I dont know where you would find them locally but you can call around to 4x4 shops or driveshaft shops and they will probably have them. Or I have found them here:
    http://www.ok4wd.com/index.php/catalog/product/spicer_u_joints/
    If you have a factory service manual or Haynes manual it will tell you how to change them out, it is pretty easy for most of them. Just be careful to not let the caps fall off and let any needle bearings fall out.
