Help! Will my 33x12.50's mount on mt 15x8's??
Discussion in 'The Garage' started by theitalian404, Jan 28, 2006.
  1. theitalian404
    theitalian404 Registered Member
    May 7, 2005
    75
    Georgia.
    pretty much what the title says. I got 4 brand new super swampers tsl's (33x12.50) and I need to know if they will mount on my 15x8 rockcrawlers? My neighbor says I need to use 15x10's...but I don't have much money right now. Please give advice if anyone can!
    thanks!
  2. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    yes they work.
    i have 33's on a 15x7 right now. Anything larger then 12.50 then yes, you should go larger in rim size, but if all your doing is pavement pounding you might be ok.
    Me personaly like the 15x8 rim with a 12.50 width tire. Saves the rim's from scuffing when rock crawling. I ran 35x12.50's on my jeep for the longest time on 15x8's no problems, not even when i aired down low.
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    i did it for a long time. It looks and functions a lot better, IMO, on x8s that x10s. I want to get some 15x8s again for my 40" TSLs.
  5. goldwing2000
    goldwing2000 Guest
    I prefer the look of the 15x10, personally.
    15x8 is better for low pressure or rock crawling stuff but 15x10 is better for street use because the tire doesn't "balloon".
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have 37x12.5s on 15X8s. I will prolly keep these rims and beadlock them when I run my 42s:D.
    Ira
