HELP! Wiring diagram on how to convert external to internal regulator ASAP!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Dune_Goon, Nov 8, 2001.
  1. Dune_Goon
    Dune_Goon Registered Member
    Mar 9, 2001
    55
    Santa Maria, CA USA
    I need to find out what I need to do to change my 1972 GMC Jimmy Alternator w/external regulator to a new alternator w/internal regulator. I need help ASAP because this thing is draining my battery quick since everything is running off the battery. I am converting to an internal type because it is evedentally better and the external regulator costs as much as the alternator with the regulator built in, so why not?
    Cameron Gunlock AKA Dune Goon
    addicted2dunes@hotmail.com
    www.Pizmo-Dunez.com
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    this is what you have to do take
    take out your regulator and put a jumper from 1st to the 3rd connector, and another jumper from 2nd to the 4th. it does not matter from what side you start. the jumpers should be connected as follows
    blue-red
    white-brown
    on the internalregulated alternator. from the rear the blue should be on the right and the white on left.
    power is obious(sp)
    anymore questions let me know.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    You can also get a kit from <a target="_blank" href=http://www.wiringharness.com>M&amp;H Electrical Fabricators</a> that contains a nice plug-in jumper and an adaptor for the alternator.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    dune_goon,
    just saw that you're near pismo. i was up there this past weekend. it was an impulse thing, i just packed up and took off, camped out at the beach and the next day i went and hiked bishiops peak. i needed an excape, it was worth it. maybe next time,
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
