help! wiring!
Discussion in 'The Garage' started by jj4465, Aug 12, 2003.
  1. jj4465
    jj4465 Registered Member
    Jul 31, 2003
    hey..well i got my lights on top of my blazer hooked together and everything and im gonna hook them to a toggle switch......i was wondering...i need a hot wire of course...instead of connecting it to the battery...cant i hook it to a fuse in the cab?...if so how do u do this...do u just jam the cable into the fuse socket and stick the fuse in or what?....thanks guys
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    Petrolia,Ontario,Canada but working in Port Huron,
    I take it the new offroad lights are rated at 50 watts or greater.
    A toggle switch mounted to the dash and wired to the fuse block will either end up causing an electrical fire or won't work for long.
    The proper way to wire up any high amp accessory is to use a relay.
    Here is how to do it properly.
    The "86" connection is a dash mounted switch that goes from the fuse box.This will be a VERY low amp draw source.This will trigger the relay and allow the full,high amp currant to go through the relay,directly to the lights.(much safer)
    The "87,to the devices"connection will go to your new lights.
    Hope that helps.
