HELP! with 1 ton change-over!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jwduke, Aug 31, 2003.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Ok guys, I need some "simple help" here! What is the Spicer number for the crossover u-joint, to go from a 1310 (10 bolt) to a 1350 (14 bolt). It would be a 1310 on 1 side, & 1350 on the other. Thanks! I tried the search, but nothing came up.
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    You either need Napa part number 348 or 447.
    The difference between the 348 and the 447 is that the 348 has the external snap rings, the 447 has the internal c-clips.
    http://coloradok5.com/forums/showflat.php?Cat=&Board=blazer4x4&Number=197115&Forum=All_Forums&Words=conversion%20u%20joint&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=195487&Search=true#Post197115
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/pimp1.gif
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Autozone Brute Force U-joint # 1330.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Its not 1310 on the driveline side it is a mechanics 3 cap which is just slightly a different size than a 1310. Thats why 10 and 12 bolt u-joints are not interchangeable.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I am pretty sure your U-joint size on your current driveshaft is a 1330. So you need a 1330 to a 1350 U-joint. Sorry but I can't find my old one to get the part number from right now.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    1330 is on a twelve bolt, he has an 87', should be a 10bolt with 1310yoke side,mech.3 on driveshaft side.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    "87" and "89" 10 bolts use the same size U-joint, mine from the factory was a 1330. /forums/images/graemlins/confused.gif
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    12 bolts use a #1310.
    To go from a 10 bolt (1330) to a 14 bolt (1350) he should need a Napa #447. /forums/images/graemlins/thumb.gif
  9. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I just did the conversion from 10bolt to 14bff and napa 447 was the wrong ujoint. I ended up getting one from Carquest. Im pretty sure the 10bolt is 1310. Ill find the receipt to be sure.
  10. La Barge
    La Barge Registered Member
    Jan 22, 2003
    68
    Gilbert , AZ
    1310 has u-bolt style straps 1330 uses a flat style strap. 1310 is on front dana 60 or dana 44. all 10 bolts front or rear use 1330's. check your dana 60 match up the u-joints. I'll bet the 10 bolt u-joint is bigger then the 60.
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A 1330 measures 3-5/8" across just like a 1350, only with 1-1/16" caps instead of 1-3/16". The 1310 is about 3-1/4" across with 1-1/16" caps. Of course there's inside and outside clip versions - just to make things fun /forums/images/graemlins/thumb.gif
  12. youngerss
    youngerss Registered Member
    Oct 7, 2002
    24
    Athens,Ga
    If you have the 1 ton 14 bolt (the one with the bigger brake shoes0 you need the 447 u-joint on the rear
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    My 87 1 ton 14b has a 1350.
  14. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    becouse of the debate that is going on , get
    both of them and return the one that doesnt
    fit /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Napa #348 if your goin 12 bolt to 14b ff.
    Napa #447 if your goin 10 bolt to 14b ff.
    Those ae not written in stone however. When we did Gokartergo's 3/4 ton swap. niether of those was right. Turned out to be Napa #448. He had some odd drive shaft yoke.
