Help with 14 bolt 10.5 ring!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PineyPower, Nov 6, 2002.
  1. PineyPower
    PineyPower Registered Member
    Jan 16, 2001
    52
    New Jeresy out in the pine barrens
    I need a digram of the inside of the carrier showing all the bearing and stuff.I really need to know what bearing i need if anyone could help me out i would apprite it.
    Aslo got a dana 60 rear axle for sale 4.56 gears locked everthing make offer.
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    which bearings do you need? The carrier bearings on the ouside of the diff? or the pinion bearings?
    Brian
    82 burb
    40" TSL's D60/14FF SM465/NP205
  3. PineyPower
    Jan 16, 2001
    52
    i need the pinion but there is a small bearing that pinion gear head sits in
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You need the pinion? You know that ring and pinons are matched sets, right? You can't mix and match them...
    I have a full set of bearings for my 14b at home right now, I can look at the pinion support bearing tonight and tell you what the timkin part # is. </font color>
