Help with 14 FF hub torque (searched)
Discussion in 'The Garage' started by RodsRVF, May 20, 2005.
  1. RodsRVF
    RodsRVF Registered Member
    Mar 16, 2005
    51
    CA
    I am putting my brake conversion on my 14 bolt FF back together and I did replace the bearings in the hubs. I searched and can't seem to find the torque spec for the nut that tightens down against the bearing and then the locking nut. (The one that take the special tool with the 6 pins on it) I found some info on the front hubs when I search but I was not sure if it was the same. I have called a few dealers and shops they all say they don't know.
    Thanks for the help,
    Rod
  2. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
  3. RodsRVF
    Mar 16, 2005
    51
    CA
    I have looked at that but I don't see the torque specs for the special nuts that go up against the outside hub bearings. Do you see it in there?
    Rod
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I think it's 50lbs could be wrong.
    TTP for you.
