help with 14bff hub bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fbronson, Jan 21, 2005.
  1. fbronson
    fbronson 1/2 ton status
    Jan 12, 2004
    104
    Denver, CO
    So I have been really scratching my head on this one. How does one go about replacing the outer bearings on the hub of a 14bff? :screwy: I can get the seal off, and the bearing by the seal out, but no matter how I look at it, I can't seem to figure out how that outer bearing comes out!!:mad: Any ideas?
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Go in from the seal side, there is a big snap ring hold the outer bearing in place. Once the ring is removed flip it over and use a punch to drive the race out through the seal opening.
    When you reinstall an outer bearing, after you put the snap ring back in be sure to flip it over and seat the race against the ring so it doesn't move when you torque the spindle nuts.
    :thumb:
  3. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    if replacing all parts . take a big long object and big f ing hamer and beat the bearing out from the front and the seal will come out also. then take the snap ring out and the rest will come out about the same. been a long time sence i had to do one of those . most the time thay look good and just clean and oil them and put new seal in. if that way dont beat the bearing out and runin it. take a chisle and beat the seal inward to the center and it will come out .
  4. fbronson
    Jan 12, 2004
    104
    Denver, CO
    Thanks for the tips guys!:thumb: I'll give it a try and see what I can come up with.
