Help with 203/205 Doubler
Discussion in 'The Garage' started by Rekless_off_road, Nov 21, 2006.
  1. Rekless_off_road
    Rekless_off_road Newbie
    Nov 1, 2005
    4
    Beaverton, OR
    Whats up guys, long time on here, haven't posted very much. I am building a suburban and am trying to figure out how to build the 205/203 doubler. Any info around on the mods and install on this. Am running the 465 tranny.
    Thanks,
  2. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    lots of info out there. Search and you could read for days.
  3. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    465/203 or 465/205 ?
    If it's the first then NWFW or ORD are both nice units along with other also available. Don't think there's any "doubler" options with a 465/205 combo , maybe Novak between the two, could be wrong as it's been a couple years since I searched out all the doubler options.
    Jeff
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have the 32splined ord dubbler with my 465
    be sure to grind the shift rails while its out of the landbarge
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Hoe much lower do you want to be? Do you need 4:1? If you dont really need 4:1 you might check out the Low max 205. I have a grip of $$ in my doubler, its beefy and built to give me no problems (if it ever gets installed that is). I have about $2,800. in my doubler. With the Low max you remove and replace, everything should fit according to their website.
