Help with 81 sub
Discussion in 'The Garage' started by mollyman, Sep 15, 2006.
  1. mollyman
    mollyman 1/2 ton status
    Aug 18, 2006
    280
    west virginia
    Hello I'm new here. I have an 81 k10 sub with a 350 4x4 with auto front hubs on a 10bolt. My question for anyone that can help is 2 parts. First how the hell do you get the front rotors off? Do I have to take out the hubs or what? Second I am going to lift the front 3" with new springs and the back 4". So in the rear can I do a 2" block with a 2" add-a-leaf and put shims in to help the rear anglr? I am just not sure if you can use this combo for the rear lift.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    1 - yes, you have to remove the hubs to get to the spindle nuts to remove the hub/rotor assembly.
    2 - I'd go with a rear lift spring or a shackle flip
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Shouldn't need to angle the rear axle if you stay with the stock D-shaft, but then you might run out of slip yoke.
    I got a clunk in the rear with the ORD add-a-leaf to level the rear after lift springs, so I took them out and I have the standard Sub sag-butt, only higher.:haha:
  4. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Welcome to CK5! it sounds like a good repair manual would help you out Pulling down the hubs is pretty simple job to the "vetereans" but can be a bit daunting to someone thats never done it go to your Parts store of choice and pic up a repair manual for your truck ..... or you could try E-bay your going to also need torx bits to remove the 5 "bolts" and a Hubsocket for it as well as a Snapring pliers and a set of mechanics pics .
    As for the rear try to avoid blocks if possible a shackle flip would be good as it would maintain your current ride
    Good luck and have fun
