help with 87 s-10 4cyl
Discussion in '1983-2005 S-Series models' started by bryguy00b, Nov 3, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok well im buying an 87 with a 2.5 and a 5 speed for 100 bucks..guy claims it ran..but when i went to look at it it wouldnt start..would crank over fine..but wouldnt start..would sputter once and a while but wouldnt pick up..he says it seems ot matter what the weather is like..(wont start in rainy weather) so i told him id give him 100 bucks for it as is..(was asking 350!) anyone got any ideas? fuel pump seems to be working..i can hear it anyway..its feul injected.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This is typically a symptom of cracked spark plug wire insulation. High humidity provides just enough extra moisture to provide thousands of paths to ground, other than the spark plug electrode. /forums/images/graemlins/wink.gif A set of wires, distributor cap and rotor would be the first thing to think about replacing.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool..thanx ill get on that!! let ya know how it goes..bascily a tune up lol..
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    put new fuel filter on it also, its at rear of cylidner head cant miss it, its a canister style filter, is hard on pump trying to pump through dirty old filter, will eventually burn up the pump, if its too noisy then its probably on its way out anyways
    i would put 80 bucks into it if you do get it and remove the cylidner head and have the head resurfaced and get head gasket kit fel pro brand and get some washers around .015" thick to put under the rocker bolt shoulders, it will run very strong like a whole new engine, i just did all that tp an 88 one of these, with VERY good results
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thanx...yea i noticed the fuel filter back there when i was lookin at it..probobly will do that to...very interesting about the head though..ill keep that in mind! thanx!
