help with 98 Jeep Grand Cherokee PLEASE transer case problems
Discussion in 'Other Rides' started by MudNurI, Mar 15, 2002.
  1. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Okay- friend of mine has a 98 Grand Cherokee- for some reason she has no 4wheel drive- 4lo or 4Hi... 2 wheel works fine.... Brought it to a local garage, 1500 bucks- 900 for the transfer case- 600 to install it-....said NO way to fix it... and its not safe to drive etc..
    she bought this almost a year ago- and has never had the 4Hi or 4Lo work- just never bothered her,,, she didnt need it anyway. So now she is thinking, if I have driven it for a year- why cant she now... they say its not safe?
    I know absolutly nothing about these things- but figured someone here would if you need more info- I'll call her and get it... so basically- can it be replaced, repaired, or what not... and can't she just get a used one if it needs to be replaced?
    brandy
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Exactly what did the shop say the problem was and all that??? Being a 98 I would kinda be skeptical about the whole tcase being bad. I'm not exactly sure how the 4wd is activated but sounds more like a vac/elec motor problem (which can be spendy to fix). I can take a look on Mitchel and AllData and find out more if need be. Also is this a quadratrac model? Those are like a 4 wd all the time truck.
  3. MudNurI
    Jul 15, 2001
    2,113
    VT
    I'll call her today and get some more info- its not a quad=track --- it has the actual lever to engange.. I though with 60,000 miles- it shoudl still be okay- BUT who knows. I am trying to find a way to find out what her warranty was- I know my new truck- would still be covered... not sure about a jeep though? Anyone know?
    Brandy
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    She is probably SOL unless she has an extended warranty or some kind of powertrain warranty. I haven't been much of a new car buyer, but I know basic warranty is 36k or so... but a lot have powertrain warranty to 60 or something more k.
  5. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I run my '95 Grand Cherokee Laredo with the 4.0 staight-six and the Selec-Trac case 650 miles a week minimum. I've never had any problems at all..this is the case with 2wd, on-road 4wd, off-road 4hi and 4lo. RENE (tRusty), also has the same case in his smaller Cherokee, no probs either. Sounds like that shop is bogus to me.
  6. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I would try a different shop or two to see what they say. Could be something as simple as a vacuum line falling off or a linkage or wire coming loose.
