Help with a 203 driveshaft
Discussion in 'The Garage' started by odoa3, Aug 6, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    Anchorage, AK
    I have a 75 K5 with a 203 tc. I pulled the front drive shaft and the ball between the two ujoints in the rear of the shaft is toast. Have the ujoints out and trying to figure out how to go about rebuilding the ball joint (?) in it. There is a yoke in between the 2 u joints has a ball that fits over a shaft that is in the driveshaft. Can you even rebuild this joint? Have never done this before, so any help is appreciated.
  2. sweetk30
    Nov 1, 2004
    horseheads , ny 14845
    need a spring and seal /ball kit. any drive line shop or napa or carquest should have or get for ya. make sure the yoke and parts that these sit and ride on are good. about 60-70 need some sort of new cv part aling with the kit . thats in my experence. good luck:wink1:
