Help with a lift kit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76 jimmy Az, Mar 14, 2000.
  1. 76 jimmy Az
    76 jimmy Az Registered Member
    Mar 14, 2000
    35
    Tempe, Az
    I have a 76 Gmc Jimmy with shock suspension. I am interesting in lifting my truck 4 inches. I got a quote on a rancho kit and it was $563. that is too much money for me now. Do i have to add leaf springs when i lift my truck? how much more likley is my tuck to flip over with a 4 inch lift? and what about this " sag" thing in the rear, how can i overcome this if i lift it
  2. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    superlift makes a nice inexpensive kit. I think rocky mountain had the best deal on it. alot less than the rancho quote. 4"lift and add aleafs will solve your blazer sag. mine did it and we added add a leafs at first then when we added the blocks for the 6" kit we put in it the sag went away go figure. 4" you are not looking at that big of a difference in height so roll over isnt much of an issue. another way to overcome the sag is have the springs re-arched.
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Goto http://www.offroaddesign.com and get a Tuff Country EZ-Ride 4" suspension. It's only $240.00 for a front springs/Block rear kit. This means you replace your front springs and add blocks under the rear ones.
    You can get new springs for the rear also, but that's more expensive. Many guys in this forum have gone with the rear shackle flip conversion, which means that you cut a hole on the rear hangers and install the shackles upside-down. That's supposed to give you about 4" of lift on lots of flex. You can use the stock springs with this setup or go with taller ones for even more lift. Check out Corey 88K5's page (look for his name on any of his posts and click on it. His profile should have a link to his page) He has detailed procedures on the shackle-flip conversion.
    Hope this helps.
    <font color=purple>////////
    Go 79s!!!
    </font color=purple>[​IMG]
  4. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    If you want to get a inexpensive lift, and are not too worried about articulation. Try a Add-a-leaf. The only thing is they are pretty bouncy. A add-a will net you about 2", you can throw a body lift on top of that you will have enough lift to sport larger tires and get the stance you are looking for. All this for about $200! The leafs will cost you about $50 each, and the body lift will set you back about $100.
    Add-a's are pretty interesting to install. Well on the front anyway. The body lift is nothing short of a pain in the arse. YOu need to remove bumpers and all that good stuff like that. While you are at it, put in a poly kit. I guarentee that you will never want to do it again.
    Corey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  5. 76 jimmy Az
    Mar 14, 2000
    35
    Tempe, Az
    Thanx for your left, now what do u guys recommend a block kit lift or a shackle flip. IS anyone saver than the other? HOw hard is it to do a shacle flip with the kit from offroad design?
    Thanx
  6. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    shackle fli wasnt even an optionwhe I bought my kit. The blocks seem to be fine. No slippage no breakage.
  7. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    76 jimmy - don't forget that a 4" lift will set you back for one of the above options PLUS new shocks all around.
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
