help with a welder
Discussion in 'The Tool Shed' started by fendereff, Mar 25, 2007.
  1. fendereff
    fendereff 1/2 ton status
    Jun 24, 2005
    207
    Aggieland, Texas
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    For the budget your on a stick welder is your best option for welding 1/2" steel. Hobart makes pretty good welders so that one should be good. I have heard ok things about the Lincoln Tombstones like you can get at Home Depot but I think that Hobart has more amp output which will be nicer when you have to weld heavy stuff.
    What are you going to use the welder for? A stick is not the best choice for most vehicle fabrication but can work. A mig is much better at that but a mig isn't as good for the really heavy stuff.
    Harley
  3. fendereff
    Jun 24, 2005
    207
    Aggieland, Texas
    it is going to be used primarily for stuff on my suburban. brackets and reinforcing connections and such. i say 1/2", but that would be the max i would ever do. i just like having the right tools for the job, so when it comes up that i need to weld something 1/2", i want to be able to. i dont see the need arising very often.
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Do you know how to weld or is this a learning project too?
    For working on a vehicle and doing fabrication/reinforcing something like this might do you better.
    http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200306073_200306073
    If you are a competant welder & can do multipass welds you can weld 1/2" with a welder like this. I have welded 1/4" plated on multiple occassions with that welders uptown brother the Miller 135. Hobart is owned by Miller & Hobart is there more no frills line and Miller is the top line.
    If you can expand your budget a little this is a great welder that will make welding heavier stuff alot easier. My welder at work is the Miller version of this and I have welded alot of 1/4" plate to 3/8" plate steel with it no problems.
    http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200328799_200328799
    Harley
  5. fendereff
    Jun 24, 2005
    207
    Aggieland, Texas
    it will be a learning experience lol.i will check those out. if i find the right welder, i dont mind spending a bit more if it will last me for a long time.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    For general purpose welding a mig is easier to use. They are also pretty easy to learn on. If you know someone who welds have them teach you or try and find a class at your local community college. I learned through a local CC & the guidence of a friend that can weld pretty well.
    I would highly recommend the Hobart 185 amp mig welder. It will cost more up front but should provide years of good service and is a very good all around welder. You will probably find it to be much more useful then the stick welder for most things.
    Harley
  7. fendereff
    Jun 24, 2005
    207
    Aggieland, Texas
    cool cool. One of my roomates used to work at a metal shop and still has a set of keys :D so he will be helpin me out a little. I am also in the engineering program at my college and will be getting into some welding and machineing classes here soon, but I want on to tinker with in the garage.
