Help with an engine code
Discussion in 'The Garage' started by sickquad, Mar 25, 2005.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    My 94 thunderbird gave me a misfire cylinder #2 code. It was running way rich, smoking, and idling like hell. Put new plugs and wires in it since they were real old.
    Reset the computer and no check engine light but still running the same. Anybody have any ideas what a misfire could mean?
    -Chris
  2. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    if its a 3.8 motor check the coolent level. thay eat head gaskets. and that would cause your smoke in the exaust. just a comon problem to check out. and if so the dealer has raised the factory milage warenty on the gaskets. cause thay were so bad.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Besides the head gasket, It could also be a bad injector(s)
  4. sickquad
    Jul 23, 2003
    785
    Ma
    Injectors, coil, maf sensor, throttle position sensor all test out good. This is weird.
  5. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    What about...
    O2 sensor?--it controls the mixture--but why only cylinder #2 has a misfire is kinda baffling--still getting that code after re-setting the computer?
    Might be a vacuum leak,intake gaskets can leak and make one cylinder run lean,and that throws off the O2 sensor reading some,and it will try to compensate for it by richening the mixture...try spraying carb cleaner around any gaskets or hoses you suspect with engine running...
    Does you car use a coil pack?-or does it have a distributor?--I have seen GM HEI"s that had a bad "tooth" on the reluctor that would cause one cylinder to skip...not sure how fords ignitions are setup..it will run rich if all the fuel isnt being burned it that misfiring cylinder..Checked compression in that cylinder??--sometimes a valve problem causes misfiring too--.
    Anyhow,good luck!
  6. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I think its time to do a compression check. Espically if it is a 3.8. If you have a bad head gasket the leaking colant will take the 02 sensor out. That will make it run as you describe.
    Have there been any other codes set?
    Did you do the KOEO and The KOER tests?
