help with an NP208
Discussion in 'The Garage' started by mollyman, Oct 2, 2006.
  1. mollyman
    mollyman 1/2 ton status
    Aug 18, 2006
    280
    west virginia
    I've got a NP208 with a slip yoke. My question is 2 parts. I'm lifting the rear 4" so I would like to know if anybody makes a SYE kit for the NP208 or where i can get a stock replacement rear driveshaft the already has the u joint pressed into it???? If i can't put a sye in then i don't want to get a custom dshaft. I also don't want to mess with pressing in the u joint. I've got an 81 K10 sub with a corp 12blt in the back. Any help would be great!!!!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Cool , you have a nice long driveshaft in the rear . If you use springs or blocks , you may ( no promises ) have no problems . My buddy has a 4 inch lift , and runs the stock shaft .
    With a shackle flip , I wouldn't know on a shaft that long .
  3. mollyman
    Aug 18, 2006
    280
    west virginia
    Yeah i will lift with blocks or springs but where can i get a replacement reaer dshat with the ujoint already in it????
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Is yours broke ? A driveshaft shop is the best place , or a junkyard . 80-81 had slip yokes and 12 bolt rears in 6 lug Subs .
  5. mollyman
    Aug 18, 2006
    280
    west virginia
    no mine isn't broke, but it needs a new ujoint where it meets the rear pumkin. and i don't know how to put new ujoints in so i just thought i would replace the whole thing and get it with a new ujoint in it
  6. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    It would probably be best and cheapest to bring your drive shaft and a new U joint to a shop to have pressed in. Then your not installing a used U joint and don't have to hunt down a used shaft. They will probably charge you .5 which will probably be about 30 to 40 dollers.
  7. mollyman
    Aug 18, 2006
    280
    west virginia
    Thanks for the info. my dshaft is pretty rusty, could i just sand paper it clean and paint it? and is there any tips on kinda of "restoring" it should i just pump it full of grease till its leaking out or what??
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If the joints have grease fittings , yes , you fill them until it pushes the old grease out of the seals on the caps . Pretty easy .
    And if you take the shaft in to get a new joint , maybe you will get to see them do it . They will use a press ( you can use a large c-clamp or ball joint press ) . It is really easy .
    Yes you can sand it , and lightly paint it . Don't get lots of paint concentrated in one spot , the shaft is balanced , no paint globs ( probably won't matter anyway ) :thumb:
  9. mollyman
    Aug 18, 2006
    280
    west virginia
    thanks for the help!!!!!!!!!
  10. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    After paying $60 for a shop to change 1 u-joint, I learned how to do it myself. I used a ball peen hammer and a rock.
