Help With Autometer Fuel Gauge...
Discussion in 'The Garage' started by HEAVY METAL, Oct 21, 2006.
  1. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    anybody put an autometer fuel gauge into their chevy trucks?....i installed mine.. thinkin thta i was using right wires... but it only mrreads past full?
    help please......:confused:
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Sounds like your sender line is grounded....
  3. HEAVY METAL
    Jan 10, 2005
    386
    k.. how do i fix thta.. i spliced ointo the factory line at the cluster plug... reverse the sender/ power
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    DO NOT put 12 volts to the sender post! You WILL fry the gauge...
    Your gauge should have 3 posts, ign, grd and sender...
  5. HEAVY METAL
    Jan 10, 2005
    386
    yes it does... ign is hooked fine...i spliced into two wires in the plug.... should i just run my gauge to its own ground?
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Sure... You should have a 6 male spade grd terminal over to the left on the inner hinge post....
    Forget what color you sender wire should be, maybe tan/white stripe... You can always run your own sender wire too...
  7. HEAVY METAL
    Jan 10, 2005
    386
    k i'll try that.. let ya know... thanks eh!
  8. HEAVY METAL
    Jan 10, 2005
    386
    k... has own ground, its own ign source at the fuse panel... followed fatory wiring on factory gauge cluster chased it to a pink with black stipe wire.....still overfull...
  9. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Does it go to empty with the ignition off?
  10. HEAVY METAL
    Jan 10, 2005
    386
    nope...stays completley full .. when i turn ign on it moves back a lil bit....
  11. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Disconnect whatever you have as a send wire and see what it does with ign off and on...
  12. HEAVY METAL
    Jan 10, 2005
    386
    the needle moves closer to the full line......
  13. HEAVY METAL
    Jan 10, 2005
    386
    i htink my gauge is fukered.....
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Sounds like it... Even just a quick shot of 12 to that sender can screw em up... :(
  15. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Not all gauges are created equal, you must have a guage that matches the Ohms resistance of your sender. Make sure you have the correct gauge, most GM senders are 0-90 Ohms.
  16. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    ok, I'll ask the dumb question...how much gas do you have?
    My gas guage works and when I fill it all the way up it sits above the F for a while...then it starts to go down...its just the shape of the tank.
    -Avery
  17. HEAVY METAL
    Jan 10, 2005
    386
    thanks man.. double checked the part number.. right one..4414.....i rdered a nother gauge... we'll see onmonday...
  18. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Now to comment on your avatar, those looks good. Who do those belong too?
  19. HEAVY METAL
    Jan 10, 2005
    386
    my wife.......:D
  20. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Are you serious, if so i'm really jealous. :D
