help with axle bearing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1st timer, Feb 5, 2001.
  1. 1st timer
    1st timer Registered Member
    Nov 26, 2000
    27
    florida
    i'm trying to take out the bearing that is on the outer edge of the axle most of it aready came out but the outer ring of the bearing is still stuck in there i actually got my 4 wheeler and hook up the winch to it and can actually move the truck to the side (knoct it off the stands and all) but it won't even move a milliliter does anyone have any idea THANKS.
  2. dyeager535
    26,980
    Assumin gyou are dealing with a 1/2 ton axle? I went to a local auto parts store and rented a 3 jaw slide hammer..with the "teeth" facing outward, so that it would grab the bearing race. The slidehammer worked very well...maybe in a pinch you could get a chisel in there, but I'd be careful not to scar the axle tube where the new bearing is going to go.
    Dorian
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I had the same problem last week on a burb in the shop. I ended up carefully cutting the bearing with a small grinder. But as Dorian said... be very careful! I must suggest the slide hammer if you arent using one.
    1987 Chevy K5 Blazer- 350 TBI
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    DEfinately try the slide hammer first. In a since this is an impact type remover. See with the winch you were using gradual force, but the impact of the slide hammer will more than likely be your answer. Im going to the parts store today to do the exact same thing. Im rebuilding my rear end, ring and pinion and all, and my seals and bearings are in there pretty good. SLide hammer with the bearing puller teeth facing outward. I think you can get a universal puller kit where you can change them around. I would recommend this route if you are buying one. This way you'll get more usae out of it.
    Will work for beer, parts and tools.
    90 Jimi,350/700R4/241/10bolts/4.10's/33's/4"
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  5. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I use the slidehamer there was one time I had to heat the axel abit to get one to come out all of them are a real bear to do. Tring to pull it out will not work it needs that hamer blow to pop out.
