Help with Brakes
Discussion in 'The Garage' started by chevyalltheway, Jun 18, 2004.
  1. chevyalltheway
    chevyalltheway Registered Member
    May 16, 2004
    12
    hey guys i have a prob with my 86 K-10 blazer brakes, when i go to stop it wanders all over the "darn" place i checked the pads roter and bleed them, after i blead them it stoped nice and true now a day later it is doing it again. i did check my brake fluid level and its the same so i dont think thier is a leak in it. do you guys have any ideas
    thanks
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Loose steering components? /forums/images/graemlins/dunno.gif
    Ill adjusted rear brakes? /forums/images/graemlins/dunno.gif
  3. chevyalltheway
    May 16, 2004
    12
    it goes down the road straight and true but as soon as i hit the brakes it wanders bad /forums/images/graemlins/yikes.gif
  4. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    Possibly a caliper sticking on one side in the front? I know you said that you checked the pads and rotor-is one of the pads worn more than the other? Does the pedal vibrate when it is pushed-could indicate a warped rotor on one side that you may not be able to see with the naked eye.
