Help with broken bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stylzz, Nov 8, 2002.
  1. Stylzz
    Stylzz Registered Member
    Sep 9, 2002
    95
    Mystic, CT
    Bare with me I want to explain what happened. Ok how stupid am I? I was taking off my AIR pump and and pipe. Job was going as easy as can be until I got to the last bolt in the manifold in the back on the drivers side. It had been soaked with PB yesterday and a couple times today. It started to turn using the same amount of pressure as the rest and all of a sudden the nut came off. So I go to the parts store and get some easy outs and still cant get it out. I'm putting so much pressure on the easy out I'm afraid its going to break. So what should I do, just leave the easy out in there as a plug or is there another way to get it out or plug it. Too bad I didn't buy my welder yet because I would just put a beed in it.
    Thanks in advance,
    Joe,
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    try heating it with a torch even if it's a propane torch, then try the EZ out... Good thinking by not putting to much torque on the EZ out /forums/images/graemlins/thumb.gif
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I would weld it but since you do'nt have one yet you could drill and retap it.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah you gotta do with what you have.
    If all you want is plug it, then JB weld could do it. But if you want a clean job, drill it and retap it, I assume you have the drill, and if you don't have the tap, that is much cheaper to buy than a welder for now /forums/images/graemlins/thumb.gif
  5. Stylzz
    Sep 9, 2002
    95
    Mystic, CT
    I would like to drill and tap it but for me to get in there I need to rent an angle drill because there is no way I can get mine in there between the master cylinder and the ac compressor. Would the JB weld work with the heat and pressure? I've never used it before so I don't know its limitations. I can't leave it the way I have it now because its just a band aid, 5/16" self tapping screw and high temp orange gasket maker /forums/images/graemlins/grin.gif. Well at least it doesn't sound like a pop corn machine.
    Thanks again for all the help,
    Joe
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually if you use JB weld instead of the orange with the self taping screw you should be fine.
