Help with Chelsea PTO ID?
Discussion in 'The Garage' started by OnetonCowboy, Sep 2, 2005.
  1. OnetonCowboy
    OnetonCowboy Registered Member
    Sep 1, 2005
    29
    TX
    I picked up a PTO and need help identifying what it will fit. The case is stamped 430, the tag is Model 420XSCBX W6 and Date is XG.
    Any ideas?
    Here's some links to pics:
    PTO1
    PTO2
    PTO3
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
  3. OnetonCowboy
    Sep 1, 2005
    29
    TX
    Yeah, I had sent them a letter. Just not counting on getting a response, but maybe they will be better then a lot of other companies. I looked through their applications and couldn't find anything that matched with SM465, NP435 or NP205.... but I'm thinking that it likely came from a GM.
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    It almost looks like something that would bolt to the pto spot on a 205.
  5. OnetonCowboy
    Sep 1, 2005
    29
    TX
    The 6 bolt pattern is pretty common, it's the # of gear teeth and pitch I think that makes the difference in what it can actually mesh with.
  6. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    I emailed them and they got back with me in about 1 business day. The PTO I had ended up fitting a np435 not an SM465.
  7. OnetonCowboy
    Sep 1, 2005
    29
    TX
    That's a pretty good response rate. When I ran the numbers by their application chart I'm pretty sure their chart is just for current pto units since I didn't get a match anywhere.
  8. OnetonCowboy
    Sep 1, 2005
    29
    TX
    I dogged it through all those Chelsea application charts and narrowed it down.
    The model # has changed, but the designators appear to remain the same.
    This should be identical to the Model 422 series.
    The XSCBXW6XG breaks down as:
    X=std mount
    S=gear ratio of 1.205:1
    CB=input gear designator for #5-P-1029 gear
    X=No Pressure Lubrication
    W=Cable shift
    6=Assembly option
    XG=Output option, shaft 3/4" w/3/16" keyway (pump kit)
    So, as to what it fits it would be the NP435 trannies, Ford/GM/Dodge. With a gear swap it will run on a NP205 and the hydraulic output for the pump can be swapped for a direct drive, although I've been considering a large hydraulic winch for the rear of my truck. :cool1: Now to find out what the 205 gears cost....
