Help with crappy running Motor.
Discussion in 'The Garage' started by PsychoticDeadGuy, Jul 23, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I just need a quick answer as to what to try and fix my problem. I pulled this code from my '87 K5. No mods to engine just did a manual tranny swap and a 205 t-case.
    24:
    Vehicle speed sensor (VSS) - open or short circuit
    problems or park/neutral switch circuit problem
    What could cause this problem?
    But this shouldnt cause the motor to miss and stumble right? I replaced the MAP, o2, plugs, wires, cap and rotor. It ran fine for a little while, like an hour but then it started running crappy again. So whats going on? I am prety sure a 24 couldnt cause this type of problem.
