help with cruse control / check engine soon light
Discussion in 'The Garage' started by BranndonC, May 1, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I have had my blazer for a week and 2 days, i use cruse control a lot, and today while using it, it turned it self off as the check engine soon light came on, the light was on and off a few times today. Also can anyone tell me if it's possible to change the minimum speed for cruise control, right now my spedometer is about 10 MPH low because of my large tires and the CC won't engage until i hit 30 MPH and i want to know if i can set it lower.
  2. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    no one has any thing that could help?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The cruise control module is a sealed unit, so there isn't anything to adjust. /forums/images/icons/frown.gif Check your engine code to see why it turned on the check engine light. That may give you a hint as to why the cruise happened to disengage at the same time that the light came on. Perhaps they both share a common signal from the vehicle speed sensor.
  4. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I dont think any vehicles have cruise controls that run much lower than 30 MPH. Is there any reason you would need cruise at that speed?
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yeah, if i'm on a long windy road where i can't see around corners or going up a long dirt road where i don't want to go faster thatn 15 or so, then i could set CC
