Help with D44 front carrier probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Sep 24, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I pulled the carrier out of mt D44 today and I was going to remove the spider gears but the carrier pin is held in placae by a pressed in pin not a bolt like most rear 10 bolts are. Now, I dont have alot of experiance with the front axel so maby someone here can help..how do I get the pin out
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Just take a little punch and nock it through.I don't think you need to knock it all the way just enough to get the centerpin out.Brady
    '73Beautiful Disaster
  3. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    p.s the ring gear has to be off the carrier to get the pin out-
