Help with Detroit install
Discussion in 'The Garage' started by sandawgk5, Sep 24, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Hey guys and gals I am getting ready to install my detroit I got from sweetK30 in my 14FF and the question I have is do I remove the shims from the side gears or do I leave them in when I put the detroit in. I think if I leave them in it will only pre-load the springs in the detroit a little. Thanks in advance.
    Ira
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I removed all the shims. If you don't the Detroit will not operate correctly! I thought I removed all the shims the first time, but realized that all were not removed when I heard a hellacious noise from the rear end. I took it back apart and found that the shims on the side gear were still in there, but were hard to see from the gear oil camoflauging them :doah:
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    The Detroit should have come with instructions, if it doesn't past the test labeled in the end,, it is not properly installed. I however did not look at that section till I realized I had a problem.
  4. sandawgk5
    Oct 28, 2003
    6,881
    I bought it used and it did not have instructions. What is this test you speak of?
    Ira
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I know that on Aussies and Lock-Rights they remain in place to properly pre-load the locker. Let me look in the install directions if i still have them.
  6. readymix
    May 30, 2004
    6,706
    26
    From TracTech, The No-Spin replaces all Side and Spider gears and shims.
    So leave them out
  7. sandawgk5
    Oct 28, 2003
    6,881
    Great thanks, I knew someone on here would know the right answer. I thought I needed to take them out cause the case did not sit down right with the shims in there.
    Thanks again
    Ira
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Definately remove ALL the shims. You should put the Detroit in a completely empty and bare carrier.
    Here are the installation instructions from www.detroitlocker.com.
    The manual you get with a new one is almost exactly what you will see in that link.
    The test that was spoken of in an earlier thread is to make sure the locker operates properly after the install. The procedure is spelled out in the manual. :D :D
