Help With Edelbrock 2101 Intake Manifold
Discussion in 'The Garage' started by bigoltrux77, Nov 2, 2006.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    I know im probably getting annoying with all my posts but, i need some more insight. Im putting this intake on my Blazer but there are some holes that i dont know what they are used for. Of course the back is for the distributor, middle for the carb, and front for t-stat housing. But there is on inbetween the carb and distributor. Like Picture below.The bigger hole closer to the carb.
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    That is for a "T" fitting for vac lines. Or for a plug if you dont need the vac lines.
  3. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    Here is a better picture. I need info on the hole inbetween the distributor and carb. And the two big holes on each side of the tstat hole.
  4. mulletman671
    mulletman671 Registered Member
    Nov 2, 2006
    29
    Avon, CT
    The one in back is for vacuum(brake booster, auto tranny, etc.) if your carb doesn't have enough ports, the two in front are coolant..... I put a nipple on one for the heater core inlet (the one on the pass. side) and plug the other.
  5. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    yeah the two in the front for coolant. I have a nipple in one, and in my application I have my temp. sensor there. I believe most take a plug though.
  6. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    What type of fitting do i need for that? And what is that hole on the left side of the carb opening? ITs directly below the carb in the picture.
  7. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    u need a plug with pipe threads and the other hole by the carb is for a divored choke u can block it off if ya dont need it
  8. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    what would i block off the divorced choke hole with?
  9. bronc3buster842001
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    go www.edelbrock .com and u can find all the parts u need there if u have trouble finding the parts let me know and ill find the part # and send them to ya
  10. mulletman671
    Nov 2, 2006
    29
    Avon, CT
    I believe the front fittings are 1/2 NPT (you'll need one plug and one nipple fitting for 5/8 heater hose or 1/2 heater hose depending on the year) and its a 3/8 npt plug for the vacuum port in back
  11. mulletman671
    Nov 2, 2006
    29
    Avon, CT
    And BTW whatever machine Edelbrock uses to thread those holes is terrible.... use teflon tape and crank em in or they'll leak like you wouldn't believe
  12. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    That manifold should've come with an aluminum block off for the choke. It looks like a square hunk of metal with a couple bolt holes. On mine there was also a small hole in that blank off which needed to be plugged.
