Help with fuel gauge issue...
Discussion in 'The Garage' started by guitarman, Jun 30, 2006.
  1. guitarman
    guitarman Newbie
    Mar 31, 2003
    Hello Blazer Gurus!! I've been lurking here for the past few weeks and am thoroughly impressed with the knowledge available at this site. My fuel gauge is pegged all the way to the right even when no fuel is in the tank and i read on the site that this is a ground problem with the line from the sending unit. I traced the wire to the break and realize i need to replace it from the tank to midway up the frame. My question is how does the wire connect to the sending unit - is there a connector at the tank or does the wire connect directly to then sending unit necessitating removal of the tank? Thanks for any help. Take care.
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    The wire was soldered to a tab on the sending unit, at the factory, IIRC.
    Because even my big 100W gun wouldn't heat it well and I refuse to use a propane torch near a gas tank, I ended up drilling a small hole in the tab and using a crimp connector to ground to it, seemed to work okay.
    -- A
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i took bare wire and small hose clamp to one line on sender. worked great for cheep fix.
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    The baffle came loose in my tank and knocked the sending unit off of the return lines. Pegged the gauge. That was two months after I dropped the tank to correct the ground wire.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yes, your sending wire is grounded making the gauge peg to the full side. IIRC the wire does have a plug so simply unplug the wire and make a new one with the correct termination so you can plug it back onto the sender then do a good solder connection to the remaining wire and use heat shrink tubing when you're done.
  6. guitarman
    guitarman Newbie
    Mar 31, 2003
    Thanks everyone!!!
    Thank you for your help everyone - doing the repair today.
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Actually an OPEN in the circut will cause the gauge to read "FULL" and a short will cause the gauge to read "EMPTY
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Well that's funny because every truck and car for that matter on a GM vehicle if you pull the wire and ground it the gauge would read full not empty.
  9. readymix
    May 30, 2004
    6,706
    26
    maybey on the newer ones. But I guarentee that if you go unplug your sender the gauge will read over full on the CBS and OBS Chevys, and if you short the wire to ground it will read empty.
  10. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    0 to 90 ohm senders read full when you ground the sending wire..
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Thank you, i knew someone would chime in eventually with the required info as to the correct answer. :thumb:
  12. readymix
    May 30, 2004
    6,706
    26
    I always though that.
    0 Ohms = Empty
    90 Ohms = Full
    I'll research it a little more and post up what I find....
  13. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Make it easy, go pull your sender wire and ground it and watch the gauge peg full. :D
  14. readymix
    May 30, 2004
    6,706
    26
    No battery in the truck...
    When I was stationed in great Lakes I had an Open in the Fuel Sender windings. This caused the gauge to read more than full. When I shorted the sender wires together it moved the gauge to empty.
  15. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    it was probably a 240 to 33....
  16. readymix
    May 30, 2004
    6,706
    26
    0 - 90 is what I replaced it with. Works fine now.
    I thought the 240's were Ford specific...
  17. sweetk30
    Nov 1, 2004
    25,537
    536
    gm is 0-90 ohms. ford is the odd ball one.
    any time i found over full it was open wire.
