Help with gear install
Discussion in 'The Garage' started by xtrmjoe, Oct 28, 2004.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I am putting ECTED's and 4.56's into my 86 blazer with 10 bolts. Since I am changeing the pinion I dont want to pull the bearing off the old one just to measure the shim. What is a good starting point for shim thickness?
    What size shims do you guys have on you pinion for 4.56 gears?
    Thank for your /forums/images/graemlins/1zhelp.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    why not use the shims that are on the old pinion. With the quality of gears available to consumers, it will probably be VERY close to correct for pinion bear preload and pinion depth.
    Chris
  3. jrsheets
    jrsheets Registered Member
    Mar 15, 2004
    68
    Katy, Texas
    yeah i used the same shims off the old pinion. Although i had to put different shims on the dif bearings, it went together perfect
  4. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    thanks for the info!
