Help with glow plugs needed...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Sep 18, 2002.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I already posted this in the diesel forum but since this forum has higher traffic volume, I'm hoping someone here can help me out.
    In the '83, when I turn the ignition switch, the glow plugs light will not come on, no click, and it's not allowing the truck to start.
    Don't know if this matters, but yesterday after the truck started and ran fine, the light would come back on.
    Any ideas? I'm new to diesel and am clueless.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Since you're new to diesels, let me try and explain the mechanics of a diesel engine. First of all, there are no sparkplugs to ignite the fuel and air. In the combustion chamber, the piston compresses plain air (no fuel mixed in). This compression is very high. Something like 20:1 or 22:1 depending on the engine. Now, as air compresses, it heats up. So, once the air is fully compressed, fuel is injected into the combustion chamber and because of the heat of the compressed air, it ignites. That's pretty much the basics.
    Now, on to glow plugs. Glow plugs are used in the initial startup of a diesel engine. Because the air flowing into the cylinder is cold, when it compresses it sometimes doesn't become hot enough to efficiently ignite the fuel being injected in. So, a glow plug basically heats up the chamber a bit in order to allow the fuel/air to ignite.
    Now I have a question for you. When the light wouldn't come on and you said the truck wasn't allowed to start. What do you mean? Did the truck physically not start, or could you not turn the key - get any cranking? Most likely the glow plugs not lighting will have something to do with an electrical connection, but without knowing a little more, I can't help you much.
    Hope my info helps you understand what's happening, and if anything I said is wrong, please, someone correct me.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The glow plugs have an electronic controller that determines when/if the plugs come on and how long they stay on. It's all based on the engine temp. The controller or the temp sensor could be hosed. A friend of mine had a 6.2 in an 81 or 82 pickup. His controller kept staying on too long and burning up his glow plugs (At around $20 each!). So he installed a push button switch on the dash to let him bypass the controller and control the glow plugs manually.
  4. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    my 6.2 has a manual button. I was considering trying to fix it the way it was supposed to be, but then I talked to my uncle. He has been a long haul trucker for about 30 years, he says he used to have a manual controller on one of his rigs, and in the cold cold Michigan winters, when nobody else could start, he would just heat his plugs up hotter than anybody else could, then he'd fire right up. I was sold at that point.
  5. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    The key turned and did get cranking like it wanted to start but the glow plugs light never turned on and wouldn't let the truck fully start.
  6. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i left you a message on your post in the garage /forums/images/icons/smile.gif
