Help with GM hardtop fasteners?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dznutz70, May 18, 2002.
  1. Dznutz70
    Dznutz70 Registered Member
    May 18, 2001
    21
    San Ramon, Ca
    Okay so I took the hardtop off for a week and well taking it off the hex bolt that goes through the tire brace started spinning. The bottom nut part thing a ma bobber had broken loose. So I held it with pliers and took the thing off. Now here I am putting the top on and I remember. So what can I do about this? I have been thinking about it and really can't think of anything simple to fix it. Any ideas?
    I did have some good luck though as I had just finished tightening the last bolt the torx security bit snapped in half. The way I look at it though at least I finished when it broke.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    have someone weld in a new one. If you don't know any one that has a welder, just prep it all your self, and take it to your local welding shop or even local college and have someone run a bead across it. Shouldn't be too much of a problem. If it wasn't the bolt that held your tire carrier in i'd say leave it out. You don't really need ALL of the bolts that are there.
  3. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    I had that happen a couple of times to my 78, I wouldn't worry about it too much. I drove around all winter with the top held on by the bolts around the cab and one bolt in each side - no leaks, no problems.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Just use a nut....
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I plan on getting rid of the spare tire holder in the truck when I get one that'll mount on front of the tailgate (swing out type).
