Help with GM part ID#
Discussion in 'The Garage' started by JeffHK5, Aug 11, 2005.
  1. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Bought a bunch of overstock stuff from a local Chevrolet dealer and ran into a part # that I'm having a hard time ID'ing. It's a new GM ring&pinion (4.10) and has a tag tied to it that says it's a "9.5-SF" and the box has a UPC code that says 12471292 . The other local Chevy dealers don't like to just "give out" info without selling me something and I was wondering if CK5 had a resident GM insider. I would like to put it up forsale and not be unsure of what it fits :confused:
    Thanks for the help
    Jeff
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    9.5 SF is the other 14bolt. Its the 14bolt 8 lug simi floater ring and pinion. 3/4 tons had them. They had a 9.5" ring gear vs. the full floaters 10.5
  3. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    I agree with you what it should be is the semi-floater but what I was wanting is someone that can verify that 12471292 part #. I'd hate to sell to some big dude and it be mis-marked :doah:
    Thanks Jeff
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    open the box, and look at the stampings on the ring gear, it will tell you everything you need to know.
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    dont forget the 88-up 5 lug under the 454ss trucks and the light duty 6 lugs.:D
  6. rocknutah
    rocknutah Registered Member
    Feb 7, 2005
    61
    slc utah
    Geared Up
    That number supercedes to a 12479360, 4.10 ratio, 1 ton and some newer 3/4 ton applications.
  7. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    So it's not a 9.5"SF if it was in 3/4 and 1 ton diffs? Then what diff is it,14FF or is it a AAM diff? The pinion has three bearing journals like a 14FF. I have had 10.5-14FF's apart but I have never put a tape to a ring gear to see which part of the gear measures 10.5, is it to the tips of the teeth?
    Gear is stamped 10 41 079 1
    Thanks Jeff
  8. rocknutah
    Feb 7, 2005
    61
    slc utah
    Geared Up
    The part number shows it to be a componant of a 10 1/2 full floater.
  9. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    Thanks much rocknutah , these parts went from the "for-sale" pile to the "to-keep" pile :D :D :D
    Thanks again, Jeff
