help with HF notcher
Discussion in 'The Garage' started by Impex, Jun 16, 2004.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    1.5 hole saw cutting 1.5 tubing, the hole cuts off more to one side than the other...am i doing something wrong?
    dosen't cut enough
    cuts to far
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    does your hole saw fit snug into the guid to the tube? is so then maybe the centering is off a little or loose.
    /forums/images/graemlins/thumb.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    mine does the same thing, im also cutting 1.5" with 1.5". im saving to by a protools notcher /forums/images/graemlins/waytogo.gif
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The hole saw is not centered on the tube. The saw is too close to the notcher, you can use some washers to move it out until it is centered with the hold down strap/tube. Put the washers between the backing plate and the clamp assembly that holds the tube. There are two bolts that hold the clamp assembly to the backing plate. However, you might need more than two washers to move it out far enough to center it.
    This is how I fixed mine...
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yes, HF or other similar notchers (even the more expensive ones) often need a bit of shimming to make them work right. Problem is, any little bit off, even due to "stack" tolerances that are individually within spec, multiplied over the length of the bar, can get it off by 1/8" or more easily. Mine is pretty close but not perfect.
    Here is another bit of advice. Cut it first. Figure out where the base of the fish-mouth will be, and add about 1/3 the width of the tube you will be joining. This way the saw only makes half the cut, and you don't wind up with razor edge ears that have to be ground down anyway. Saves the saw which lasts twice as long, and even if it's off a little bit, it doesn't really matter.
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Your doing ok, that thing is a POS, but it works. I just use the grinder to clean it up a bit when I'm done cutting...
  7. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Russ has it right.....you can't "holesaw" through the middle of a tube!!! /forums/images/graemlins/yikes.gif
    It's an end-notcher...if you're trying to notch 2" tube the cutting blade should only have about 3/4" over the tube, and the rest of the blade should be hanging over the edge of the work.
    It's amazing that you were able to cut as deep as you did, with that much drag the blade should have been binding up and chattering like crazy!!!!!
    /forums/images/graemlins/thinking.gif
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    What about using a 1 7/16" hole saw? /forums/images/graemlins/thinking.gif
  9. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    .474375" over the tube.
    .963125" hanging over the end.
    Smarta$$ /forums/images/graemlins/grin.gif
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    so is that good or bad? /forums/images/graemlins/dunno.gif /forums/images/graemlins/confused.gif
  11. Impex
    469
    Chandler, AZ
    i just cut it in the center to show so i could take a pic (if you look close i tried notching the very end and didn't work)
