Help with Hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lukerz, May 18, 2001.
  1. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    I can't find my book and want to remove my hubs. I have gotten as far as removing the cover, snap ring, and using a special socket removed the nut. What is next ?
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  2. Blazerblk
    Blazerblk Registered Member
    Jan 23, 2001
    15
    Chicopee, Ma
    There are two nuts to take off and some kind of lock washer that sit between the nuts. Then just pull the hub off. The washer won't turn, it just slides off.
  3. lukerz
    Apr 13, 2001
    109
    Western Mass
    How do I pull off the second nut? The first one came off with the expensive special tool.
    Th350 Np203 355 CID
    31 X 10.5
  4. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Lukerz,
    Use the search button! There are many posts on this that even have pics.
    Not sure myself, but you can find it if you 'search'.
    Good luck
  5. lukerz
    Apr 13, 2001
    109
    Western Mass
    I did, no go on that. They had a write up on switching from 6 to 8 lug and left out all yhe picture info I could have used. Thanks just the same. If you come across any ...
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  6. lukerz
    Apr 13, 2001
    109
    Western Mass
    anyone????
    Th350 Np203 355 CID
    31 X 10.5
  7. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    All the ones Ive ever done used one socket for both nuts.
    Proving once again that man CAN live on beer alone
  8. backlash
    Oct 21, 2000
    519
    Northern, VA.
    When you did a your search ... did you change the default setting to all posts? There's tons of stuff there! Also I'm pretty sure pre and post 86 are different! I could tell you how to do mine ... an 88 but that would not help you with an 83 (I think).
    Also ... I'm presuming you mean you are removing your locking hubs ... not your hubs. Hubs held to rotors by the lugs!
    Wish I could help more.
  9. lukerz
    Apr 13, 2001
    109
    Western Mass
    Actually both and I am done. The washer seperating the two nuts has holes in it. I used my slip ring pliers to grab this washer to remove it an lo and behold I found the second nut. Now if I just fix the nut behind my wheel. Any suggestions on that???
    Thanks for all that helped
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  10. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    What nut behind the wheel?
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  11. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    After you take that other inner nut off (the one behind the washer with holes in it, using the same socket as the outer nut, the hub will come right off. Well, obviously you will have to remove the caliper first.
  12. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    nut behind the steering wheel.....I got the same problem.
    Makes me think of the bumper sticker....
    "If you don't like my driving get off the sidewalk!"
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
