Help with hydro assist install w/o heim joints
Discussion in 'The Garage' started by Blazer79, Nov 9, 2005.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Hello:
    I bought a ram from surplus center. It's a 1.5"x8" ram but has no heim joint ends. When we were taking measurements to install it we noticed that the drag link not only moves sideways and front to back, but it also moves up and down (about 1/2") due to the angled knuckles in my Dana 60 (and all axles, I think).
    It seems to me that something will eventually break if I install it without the heim joints, but I know many people have installed it like this.
    Can anybody with a setup like this tell me if it has held well or did something eventually break? Maybe post some pics?
    I could add a couple of heim joints, but that would be too expensive. The cost is the same as buying another ram because of shipping & handling & taxes, since I'm outside US.
    Any help greatly appreciated.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    It only has one run on it, but mine just has big clevis ends with pins. I ordered the tabs with about 1/16" of play in all directions on purpose. Call me redneck, but it's worked so far.
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    When I installed my ram I did not lign up the mounting tabs parallel with each other. I also have a small amount of play in the tabs which gives the ram plenty of room to move without binding up. So far I have about a dozen trail rides and some street miles on my setup with no malfunctions to speak of.
  4. Blazer79
    1,816
    The reason I'm installing the ram assist is to get rid of death wobble. If I leave some play on the clevis, won't that still allow death wobble to happen?
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Installing ram assist will not solve death wobble it will only cover it up. Call ORD and order there Dana 60 Kingpin Bushing and Spring kit it is only $17 for both sides. Add your existing spring cup to the top of the new spring to add a little extra pre-load and you should be good provided you Kingpins are not shot. Are you sure it is death wobble and not a bad TRE?
    Ira
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I ran into the same thing mounting to the tierod. It moves or kinda twists as it turns one way to the other. I tacked it up so it was in the middle of the movement and then checked each way and the tie rod ends have enough movement that it works ok. Here is a pic of mine:
  7. Blazer79
    1,816
    Sandawg:
    I already replaced everything at the ends of the axle. I ordered the complete kit and not just the plastic bushings, but that didn't solve it.
    I did have a bad tierod, but now I'm replacing everything with new bars and heim joints. Hopefully that will help too.
    Thanks.
