Help with installing new locking hubs!
Discussion in 'The Garage' started by Saxwonder84, Jun 15, 2004.
  1. Saxwonder84
    Saxwonder84 1/2 ton status
    Jun 27, 2002
    117
    Rockwall, Texas
    I'm in the middle of changing my old hubs with some warn premiums but I can't get the old hubs out. I've removed the cover and spring and taken out the lock ring which let the center cog (i guess) come out, but the instructions say there is a retaining ring but I can't find it and the rest of the inners won't come out. Can someone plz help?
    Jacob Byrd
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Look at the very outside of the hub body inside the wheel hub. There is a lockring that retains the locking hub body. It is in a groove inside the wheel hub. You have to pop that out to get the locking hub body out. A couple small screwdrivers, awl, etc you can pop it out. A dental pick works like a charm too if you have one.
    Harley
  3. Saxwonder84
    Jun 27, 2002
    117
    Rockwall, Texas
    Can't find the things. Dang
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is just a round piece of thick wire. there should be a gap of about 3/8" or so someplace around the hub. Just drag your finger or screwdriver around the edge of the hub and you will find a gap.
    Harley
    Harley
  5. Saxwonder84
    Jun 27, 2002
    117
    Rockwall, Texas
    Thanks I found it but man I can not get that thing off. I lack small screwdrivers and I don't have a dental pick so any other helps on getting thta thing off?
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Try and get something pointy. Knive, flathead screwdriver, etc underneith the ring. Then grab the ring with some needle nose pliers.
    Harley
  7. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    pocket knife works good, after you get it off the lip put a screw driver behind it and run it out, but invest in some pics to get it out next time. Also make sure the hub and egged or you will never get hubs in or out. The warn premiums are a good investment though. good luck
  8. Saxwonder84
    Jun 27, 2002
    117
    Rockwall, Texas
    I finally got it all back together and low and behold IT NEVER DISENGAGES!!! Oh man this is a trip. So much for easy install or am I mechanically disinclined? Some plz help.
