Help with intermittent shimmy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by turbo, Jun 8, 2001.
  1. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    I have a 82 3/4 ton (8600 GVW) burb basically stock. It has the factory 4 front shocks and the steering stablilizer shock.
    On rare occasion when brake is applied there is a substantial front shimmy with assoc steering wheel shake.
    First time I thought front wheel might be loose.
    Only happens occasionally not very often but very pronunced.
    Tire wear normal
    tracks and steers normal.
    Tows normal only happens with braking and then only sometimes.
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    mine does the same thing.....partly because of the cheap rotors i have on the front (a little warped), and partly because the shimmy gets exaggerated (sp?) because of the washboard of the road. busy intersections seem to be the worst because the road is rougher there.
    my whole front end is new, so this is all i can think of.
    AIRBORNE!!
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    sounds like warped rotors to me... could also be made worse by a weak or bad steering stabilizer. I'd also double check the frt end to make sure it is tight, you never know.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
