help with motor building
Discussion in 'The Garage' started by BranndonC, Sep 28, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    what part do i need to hold the sproket onto the crank shaft, i see its a pin that slides in, but what ALL does on the crank shaft. i need to know what i need to order. Thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a woodruf key, prolly less than $1. not sure if it takes the straight one of the curved one. you should be able to tell from the cutuot on the crank.
    there are 2 curved ones on a sbc, not sure about the caddy
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    That is called a "woodruff key". I don't know if there is a specific name for it as applies to chevy motors, but if you tel someone who knows, that you need the woodruff key that goes on the crankshaft they should know what your talkin' about. If you're ordering it at Kragen or other parts store, good luck!
  4. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Ha! beat me to it. BTW to figure out the size you need, just measure the width of the gap with a mic, prolly somethin' like an 1/8" woodruff key. I think home depot has them in their hardware swection in the drawers of plastic boxes with the specialty hardware in it. My local True Value carries them, bith straight and curved.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok, so i get a "woodruff key" what else goes on there... a harmonic balancer? what is everything that goes on there, i am a noob (duh) and want to know what i need, so i dont have to go back again. Thanks guys /forums/images/graemlins/thumb.gif
  6. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Yes a harmonic balancer will go on there after that sprocket here's a overall pic
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    better put the timing chain on after you install camshaft then the timing chain cover before you install the balancer. also when you install the balancer use an installation tool. some guys will just pound them on.
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    are all balancers the same? or do they make better ones? i see a lot in jegs, but not sure /forums/images/graemlins/peace.gif
