Help with my 14FF disc brackets
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Jan 6, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Hey all, I am rigging up the rear discs on my 14 bolt that I bought from misfit. Can anyone tell me what part # to get for the rubber hose and where to get it, or is TMS my only option here? Also what did you use for the bracket between the hard line and the rubber line going to the caliper?
    Brent
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Before anyone can give you a part number for the hoses, do you know which calipers you are using? D44 or 10B calipers? Both use different size banjo bolts.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I am using D44 calipers. I guess I dont need the actual part # just what hose to ask for...I figured a set of front hoses off of a late 70's K20 should work. What did you use for your brackets?
    Thx
    Brent
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Eldorado calipers also have different fittings
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those D44 calipers and hoses are exactly what I got from my parts store. I asked for '75 K20 parts.
    If you get this year of parts, the rubber hoses will be ALL rubber, no steel line on them like the newer trucks with the 10B calipers.
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    How about the hose bracket? I am going to the hardware store now to see what I can make up...
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Fab your own with angle iron.
