Help with my Windshield wipers!
Discussion in 'The Garage' started by tch777, Nov 14, 2003.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Here is the problem. Turn them on to delay no delay just low speed always on. Turn them all the way on and you get the high speed always on. Turn them off and they stay running on the low speed. Turn to "mist" to manually turn off.
    I have replaced the swith on the turn signal stalk. The regulator box under the dash and the wiper motor itself. No luck they still don't work right.
    I have Cruise Control and it does work fine. What am I looking for now? A short? If so Where is a likely place? Lots of wires under the dash and stuff.
    Tim /forums/images/graemlins/ears.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I wonder if you have a bad ground wire somewhere that could be causing that.
    Sounds like you've replaced everything else.
  3. tch777
    Jan 15, 2003
    244
    Here is what it was a loose connection on the wiper motor.
    The plug on top with 2 wires. If the connector is pushed in to far it doesn't make contact. Push in just snug and it works. /forums/images/graemlins/thumb.gif
