Help with Offroad lights
Discussion in 'The Garage' started by RodsRVF, Apr 11, 2006.
  1. RodsRVF
    RodsRVF Registered Member
    Mar 16, 2005
    51
    CA
    I want to buy some offroad lights but I need some help. Will I notice a difference between a 6" and 8" light? KC makes a 6" in 150w and their 8" is 130w, why would they not make the 8" in 150w too?
    Thanks for the help.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    you could call KC and ask them.. as they designed them and should know..
    I believe the bigger the lights the less Watts you need as it will produce a broader beam...
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The bulbs are probably interchangeable.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    KC's 150 watt bulb is a sealed beam, aircraft landing light style of bulb. The 130 watt lights use halogen lamps inside. :) 8-inch lights are freakin' huge... :rolleyes:
