Help with possible brake problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Jan 17, 2003.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Recently the Brake Light on my '90 Jimmy came on. At t first I thought it was the e-brake, but after disconnecting the switch from the circuit, the light stayed on. Brake fluid levels are normal, and not experiencing any problems with the brakes. Could this be the proportioning valve going bad? Any suggestions would be appreciated.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My scan tool can also scan the brake codes...i dont know, but you might be able to use a paper clip and get some trouble codes from it
