Help with rear shocks
Discussion in 'The Garage' started by Haulgas, Nov 24, 2002.
  1. Haulgas
    Haulgas 1/2 ton status
    Mar 25, 2001
    208
    Phoenix Az
    I broke my left rear upper shock mount and the right side frame is cracked all around the bolt. I was thinking about doing the inboard relocation untill I did a search and saw that some guys had problems with the rear leaning to much in curves and off camber stuff for a daily driver. So what other options do I have? /forums/images/graemlins/1zhelp.gif
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Alot of conditions have to be considered with the inboard setup. If you have stiff shocks, the inboard setup could help by reducing some of the dampening(making the shock seem softer which could give a better ride).
    Also it seems that many of those who were stating that they have stability problems were running really soft rear springs(such as the 57" furd springs). I run stock rear springs with a shackle flip and dont have problems with stability.
    I made my relocation bracket and I didnt move the shocks all the way to center(such as 55willys setup). The mount I made puts the top of the shocks about 6" apart and I made new lower mount that are about 1" or so from the spring perches.
    The only problem I have with mine is that I didnt take into consideration I still had to install my 2" body lift so Im gonna have to make a new mount since I will be able to go another 2" higher. /forums/images/graemlins/thumb.gif
    If you would like, I can take pics if it would help at all.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I just made this setup. its nothing more than 2" flatbar 1/4 thick weld around the axle and 2" angle 1/4 inch thick for a cross member. Some have said they had trouble with the angle but i'll have to wait and see.
  4. Haulgas
    Mar 25, 2001
    208
    Phoenix Az
    Outlaw,
    If it not to much trouble I sure would like to see some Pic's. I Pm'ed 55Willy but haven't heard from him yet.
  5. Haulgas
    Mar 25, 2001
    208
    Phoenix Az
    Sapper,
    Please yet us know.. /forums/images/graemlins/rolleyes.gif
  6. outlaw612
    Feb 11, 2001
    2,342
    Ill get some for ya. Ill let ya know when i post them.
  7. sapper
    Jul 11, 2001
    3,052
    NoVa
    well so far so good. i took it out tonite and hit some pretty bad bumps at around 65 mph and all is good. i would say initally that this will work unless you are going to go out and play Dukes of Hazard /forums/images/graemlins/thumb.gif
  8. Haulgas
    Mar 25, 2001
    208
    Phoenix Az
    Thanks guy's for the help /forums/images/graemlins/grin.gif
  9. outlaw612
    Feb 11, 2001
    2,342
    Sorry that it took so lond, but Im in the process of doing a body lift so i waited to get pictures till I took the bed off so you could see it better. I put them in my webshots.
